Gary_M Posted September 24, 2014 Share Posted September 24, 2014 Any idea if the Room Planner app is going to be developed for PC's? If so when? Link to comment Share on other sites More sharing options...
KilgoreTrout Posted September 25, 2014 Share Posted September 25, 2014 I heard they are working on an android version but I haven't heard anything about a pc version. If all you want is a quick and easy program to draw a plan, I would check out one of the Home Designer products. If all you want is something to view plans, then you should check out the free viewer program. Link to comment Share on other sites More sharing options...
Gary_M Posted September 25, 2014 Author Share Posted September 25, 2014 Nope. Have had Chief since v10. Asking the question because I'm thinking it might make life easier when going to measure a house. I don't want and I-pad. Link to comment Share on other sites More sharing options...
KilgoreTrout Posted September 26, 2014 Share Posted September 26, 2014 If the only reason you want to use room planner is because you want to use the disto, you might want to check out this article: http://www.chiefarchitect.com/support/article/KB-01846/ Link to comment Share on other sites More sharing options...
lbuttery Posted September 26, 2014 Share Posted September 26, 2014 the Disto type laser measuring devices can be used without room planner or any other software they are used instead of a tape some say a tape is never needed again I find it easier to use a tape - sometimes - for small distances - say about the length of my arm spread my Disto's min distance is 9 inches, max is 300' Lew Link to comment Share on other sites More sharing options...
TomKen Posted October 1, 2014 Share Posted October 1, 2014 I use Chief Architect X6 on my surface pro and a Disto D330i to do as is floor plans. The Disto transfer software will input dimensions directly into the Chief dimension dialog box. I looked at room planner and even it did work on a PC I feel it is just to simple to use to do a full field measured house plan. Link to comment Share on other sites More sharing options...
Gary_M Posted October 1, 2014 Author Share Posted October 1, 2014 Thanks Tom. I am coming to that same conclusion. Not in the budget for this year though for buying the Surface Pro. Link to comment Share on other sites More sharing options...
