stacimunic
Creating shower dams
Hello,
I am very new to Chief Architect and I am trying to find the best way to create a shower dam (the short 3" wall on the floor of a shower that prevents the water from escaping out of the shower), This wall will also hold the glass walls and doors that the user will access the shower from. Is that created by doing a pony wall, with a 3" lower half or is there a better and easier way to create this?
NOTE: I am using version x11 Interiors (not the PRO version)
16 minutes ago, stacimunic said:
Hello,
You should be able to do the Pony Wall with glass, and set the height of the lower half to 3", ok
for the raised threshold at the shower entrance, I generally just use a slab and assign tile to it. Like to keep it simple.
    27645
    ChiefUserTyMN
    ChiefUserTyMN
  • Similar Content
    • By MichaelaS
      The wall shown is on the same plane with a false gable roof above only a portion. The wall from the interior will reflect the same ceiling height as the rest of the home, but from the front elevation I would like the wall to be taller to move my gable up. How can this be done in CA as the wall heights are dictated by the room's ceiling height?
    • By StructEng58
      Hello All,
      I am working on a project, which its an addition to a service garage with an apartment above. The problem that I am having is that I need a new wall against an existing in order not to see a hole in the area of the existing wall. As you can see in the image of the second floor plan below where I circled it is where I need to add another wall.
      As you can see from my front elevation. I have a hole in the area where there is no wall.
      I have attached a back-up of plan to this email for reference also. I am open to other suggestions on how to fix this issue.
      Thank you in advance for the help.
      Chris
      RB Garage.zip
    • By Designer100
      Does anyone know ho fix issues I have on this commercial remodeling addition?
      1) Windows and bar cabinets are not against the wall!
      2) wall is not showing on full camera looking back toward where it attaches to the existing building. Wall existing is brick on inside, unless I decide to cover it with gypsum bd!
      3) I have a 10 ft. plate with 9 ft dropped ceiling 2 ft x 4 ft acoustic tile in new addition.
      x12
      Newell Cheatham
    • By KirkHodgson
      I'm looking to make my retaing wall larger than the terrain heights.
      In the instructions in this page, https://www.chiefarchitect.com/support/article/KB-00652/changing-the-height-of-a-retaining-wall.html
      I did all the steps, but the last point. In section/elevation, when I try to click the retaining walls, nothing happens. I don't get boxes or any selection at all.
      What is happening that I can't make this selection?
      I want to make my wall 6" above the grade/terrain elevation, and I want to drop the foundation of the wall by 24". How do I do this?
      Please assist.
      Thank you.
