More Dormer Stuff
4hotshoez
Those are auto-generated invisible walls, the program by default connects "Island Rooms" to exterior walls with auto-generated invisible walls. This is necessary due to the programming and function of Chief so that rooms placed inside other "rooms" will still appear properly in camera views. Why this is so, you would have to have a Chief Architect Inc Programmer-software Architect explain but it has always been so from the beginning of the software. If you do not want to see them the "Walls, Invisible" layer can simply be turned off while in Plan View. Deleting them would cause unwanted results in terms of camera views.
There is a setting in Edit - Preferences that controls whether this automatic function is on or off but it is better to leave it "on".
Part of learning this software is learning why it does certain things automatically, what its limitations are and what its common tendancies are, just stay with it.
