Floor to floor switching
ADACFGB
25 minutes ago, ADACFGB said:
Is there a way to connect a switch at the bottom of the stairs to the switch at the top to make a 3way switch?
I believe this question has been asked before and I did a quick forum search but didn't find it.  I believe you will have to place the 3 way symbol on each floor at the stair, and place a note on each floor to that switch, stating the 3 way connects the first and second floor to the stairwell light or etc.BTW it would be helpful if you would go to your Profile, select it, then select settings, then Signature and fill out your signature, and include the Soft ware version you're using along with your computer info for future post and speedier answers.
