Ridge_Runner Posted March 22, 2019 Share Posted March 22, 2019 I am having a problem with Rich text adding double arrows, one on each line segment. It just started doing this in X10. I have looked in Help and looked thru numerous pages on Search and find no option to even add a second arrow, much less turn it off! Very frustrating. Anyone know how to change this to just one arrow? One old topic suggested the Connect Line Segments might be turned off, but that is not the case; I checked and it is On. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted March 22, 2019 Author Share Posted March 22, 2019 Got out of CA, restarted, and the arrows are working again - only one arrow. This kind of junk drives me crazy sometimes! Link to comment Share on other sites More sharing options...
glennw Posted March 22, 2019 Share Posted March 22, 2019 Are you using a Leader Line with Rich Text? I can get what you describe if I use Disconnect Edges on the leader line once it is drawn. But as far as I know, you cant set Disconnect Edges and then choose the Leader Line tool - Choosing the Leader Line tool automatically toggles off Disconnect Edges. Or..are you using Text Line With Arrow, in which case the Connect CAD Segments toggled off, will result in what you describe with the arrows on each segment when you drag a multi segment line. Can you post back and describe exactly what tools you are using. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted March 22, 2019 Author Share Posted March 22, 2019 6 minutes ago, glennw said: Are you using a Leader Line with Rich Text? Thanks, Glenn. That's what I am using. Almost all of my condocs use Rich Text; I've done it that way for years. This just started today all out of the blue. I turned Connect CAD Segments off and back on just to see if it would clear up; it didn't. It cleared up after I rebooted as I noted above. I tried it again just now with Connect CAD Segments turned off. I only get one arrow using Rich Text in that scenario also. I don't have a clue what might have triggered the strange behavior. At least it is working now like it is supposed to. Link to comment Share on other sites More sharing options...
Spectrum-Design Posted April 28, 2019 Share Posted April 28, 2019 I get that sometimes - seemingly randomly. The only thing I've observed is that when it occurs, it is typically that the second segment (between the text and the segment that is supposed to have an arrow) is relatively short. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted April 29, 2019 Author Share Posted April 29, 2019 Interesting; not sure that was part of my problem but could have been. Link to comment Share on other sites More sharing options...
