RobWhite Posted March 14, 2019 Share Posted March 14, 2019 Where do can I change the Glazing Type in the window schedule. There is a default setting somewhere, that I need to change. Thanks you to the CA experts. I don't take for granted the speed and specialist information provide on this forum. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 14, 2019 Share Posted March 14, 2019 6 hours ago, RobWhite said: Where do can I change the Glazing Type in the window schedule. There is a default setting somewhere, that I need to change. Thanks you to the CA experts. I don't take for granted the speed and specialist information provide on this forum. Not quite sure if you mean the Glass or Glazing Type eg DBL Glazed or Single Glazed? In the Particular Window ...... Change the Material...ie apply the new Glass type .... OR In the Particular Window ..... Change the Glazing Type on the Energy Values Tab under Assembly. ( can also adjust the insulation factor here) This can also be done in the Plan Defaults>Window if you want them all Changed too. M. Link to comment Share on other sites More sharing options...
