CUJojo Posted March 3, 2019 Share Posted March 3, 2019 I want to create a simple multi line multi column text with grid lines. does anyone have a suggestion on how i can control the grid height for each row of text? Link to comment Share on other sites More sharing options...
Chopsaw Posted March 3, 2019 Share Posted March 3, 2019 Standard text allows you to create a basic schedule manually or you can convert an automatic schedule to editable text. You can also paste in a schedule from excel, or print and excel schedule to pdf and import that. Would any of those options work for you ? An example might help. Also good to know what version of the software you are using. Link to comment Share on other sites More sharing options...
CUJojo Posted March 3, 2019 Author Share Posted March 3, 2019 I had hoped to keep things native to the drawing so i dont have to manage an external file. Pasting an excel seem to paste only an image... I am on X10 Link to comment Share on other sites More sharing options...
Chopsaw Posted March 3, 2019 Share Posted March 3, 2019 Edit > Paste Special > Paste As: Rich Text... Then you can edit within Chief as a Rich Text Chart or Schedule. Without knowing what type of data you are wanting to display this would be my closest guess for a solution. Link to comment Share on other sites More sharing options...
glennw Posted March 3, 2019 Share Posted March 3, 2019 As Chopsaw said, use standard text. On the Attributes panel, use Tab Stops to create the columns and check Display Border and Display Grid Lines. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 3, 2019 Share Posted March 3, 2019 Glenn I went with the Rich Text suggestion because I assumed in mentioning the grid height for each row that they needed to be different otherwise Standard text would work fine. Link to comment Share on other sites More sharing options...
glennw Posted March 3, 2019 Share Posted March 3, 2019 Chopsaw, The row height is handled automatically. Ie, the text will wrap and make the row taller if it is too wide for the column. So each row can be a different height. You can drag the columns to be narrower or wider and the contained text will wrap and change the row height dynamically. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 3, 2019 Share Posted March 3, 2019 Yes but have you tried Rich Text ? All the benefits of Rich Text in a Schedule with the exception that it can't start in chief and you are pretty much stuck with the original number of cells. Even if we had the option of font size in the header line of Schedules and Standard Text charts it would be helpful. Link to comment Share on other sites More sharing options...
CUJojo Posted March 3, 2019 Author Share Posted March 3, 2019 What i am after is simple. Just want to be able to control the height of the columns. the table will have the following sample that i have entered in a simple text box, tab delimited. i control the column width in the grid, but cant seem to control the row height. ROW 1 ROW1A ROW 1B ROW 1C ROW 1D ROW 2 ROW2A ROW 2B ROW 2C ROW 2D ROW 3 ROW3A ROW 3B ROW 3C ROW 3D Link to comment Share on other sites More sharing options...
Chopsaw Posted March 3, 2019 Share Posted March 3, 2019 Other than adjusting the font size and that automatically making the row height like other apps. I am not sure there is a solution short of drawing a grid with cad lines. Any suggestions Glenn ? Possibly a custom font but you would need someone like Michael for that. Link to comment Share on other sites More sharing options...
glennw Posted March 3, 2019 Share Posted March 3, 2019 I don't understand why you need to manually control the row height - unless you want different size text on different rows - which you can't do. The row height is automatically determined by how much the text in the cell needs to wrap. I just noticed there seems to be a problem with the location of the row grid lines. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 3, 2019 Share Posted March 3, 2019 Glenn is that X11 or just your Mac acting up ? The chart on the Right is Rich Text and a border with 6 cad lines. Link to comment Share on other sites More sharing options...
CUJojo Posted March 3, 2019 Author Share Posted March 3, 2019 I wanted a bit more space between lines of text. the default looks crowded to me... Link to comment Share on other sites More sharing options...
Chopsaw Posted March 3, 2019 Share Posted March 3, 2019 So like my black Rich Text example or even more space ? It is double spaced but you can make it what you like. Link to comment Share on other sites More sharing options...
CUJojo Posted March 3, 2019 Author Share Posted March 3, 2019 On 3/3/2019 at 6:51 AM, Chopsaw said: Glenn is that X11 or just your Mac acting up ? The chart on the Right is Rich Text and a border with 6 cad lines. Expand The right is what i have now... text with cad lines...too much to manage... How did you add the grid on the rich text? Link to comment Share on other sites More sharing options...
Chopsaw Posted March 3, 2019 Share Posted March 3, 2019 On 3/3/2019 at 7:00 AM, CUJojo said: How did you add the grid on the rich text? Expand Cad lines unfortunately. On 3/3/2019 at 6:51 AM, Chopsaw said: The chart on the Right is Rich Text and a border with 6 cad lines. Expand You can add some space below the text with the cut and paste Rich Text method but it looks funny. I think there are actually a good number of people that share your concern here but it has been that way for so long that it is unlikely too see a change from CA. If you have a lot of work to be done that way I would contact @Alaskan_Son ( Michael ) about the possibility of a customized font or maybe even a special existing one. I might even be interested as well if the price was reasonable. Link to comment Share on other sites More sharing options...
glennw Posted March 3, 2019 Share Posted March 3, 2019 On 3/3/2019 at 6:51 AM, Chopsaw said: Glenn is that X11 or just your Mac acting up ? Expand It could be a mac thing. I get the same problem with the grid lines in X10 Link to comment Share on other sites More sharing options...
CUJojo Posted March 3, 2019 Author Share Posted March 3, 2019 Here is one i have that i had to place a blank line between to get some text separation Doc1.pdf Link to comment Share on other sites More sharing options...
Chopsaw Posted March 3, 2019 Share Posted March 3, 2019 Yes I see what you mean but even that looks conspicuous in a way. For future reference only post .pdf files when there is a pdf issue. A .jpg screen capture is preferred on the forum when it is appropriate. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 3, 2019 Share Posted March 3, 2019 You might consider putting this in as a suggestion as I was messing around in Excel to try something out and realized this feature has been available there for quite some time. Also you might experiment with a schedule containing a 3D view as it's size can be adjusted and that effects the rest of the formatting for the schedule. See this thread with the opposite problem : https://chieftalk.chiefarchitect.com/topic/21574-window-and-door-schedule-display/ Link to comment Share on other sites More sharing options...
Chopsaw Posted March 6, 2019 Share Posted March 6, 2019 On 3/3/2019 at 6:30 AM, glennw said: I just noticed there seems to be a problem with the location of the row grid lines. Expand On 3/3/2019 at 7:11 AM, glennw said: It could be a mac thing. I get the same problem with the grid lines in X10 Expand Glenn I was able to reproduce this and it seems to be dependent on the height of the text. Curious as to what yours was set at ? Link to comment Share on other sites More sharing options...
glennw Posted March 6, 2019 Share Posted March 6, 2019 Chopsaw, My default text size is 125mm. And you are correct, the bigger the text, the less of a problem. The attached pic is using a text size of 1000mm, and there appears to be no problem. But go down to a text size of 100mm causes the text to overlap the grid. I will submit a bug report. 1000mm text: 100mm text: 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted March 7, 2019 Share Posted March 7, 2019 On 3/6/2019 at 11:12 PM, glennw said: I will submit a bug report. Expand Well isn't that a pickle. I noticed the problem doing a plot plan schedule with 30" text but default for 1/4" scale is 6" and works fine but then enlarged to 72" also seem to work. Seems to maybe be a zone, but not the same in metric. I will do some more testing. Link to comment Share on other sites More sharing options...
glennw Posted March 7, 2019 Share Posted March 7, 2019 Chopsaw, I sent in a bug report and Brian could duplicate the problem and has added it to the list. But the more info and reports, the better. 1 Link to comment Share on other sites More sharing options...
vedika31 Posted March 11, 2019 Share Posted March 11, 2019 Thanks Chopsaw for the answers..!!! Link to comment Share on other sites More sharing options...
