ACADuser Posted February 27, 2019 Share Posted February 27, 2019 This is a nonstandard building, i.e. not a house Drop ceilings at 9' and 16' The two roofs slopes to rear at 1/4" per foot. Taller roof baseline is 16' AFF Lower roof baseline is 12' AFF There is another low roof under the 16' roof that pops out from under it. So should I set the ceiling height at 16' and No flat ceiling? And add roof planes at the desired heights. Set the Roof plane Structure to reflect a built-up roof? 2" pan & 8" insulation Roof surface TPO Add bar joist manually. Just wanted to confirm that this is the best approach. I have tried the second-floor technique used by Joe but I can not manage that well. Thanks for your input. va z hills revised plan.pdf va z hills section.pdf Link to comment Share on other sites More sharing options...
javatom Posted February 27, 2019 Share Posted February 27, 2019 You may need to set all your rooms to have no ceiling and then manually add ceiling planes for the variations. Link to comment Share on other sites More sharing options...
