ComputerMaster86 Posted February 27, 2019 Share Posted February 27, 2019 Do any of you guys get door jambs when you mull a fixed door with an hinged door? I am wondering if this is a bug in X11? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 27, 2019 Share Posted February 27, 2019 Good catch. Easy to reproduce too. Its not just fixed and non fixed doors. Its doors in general mulled to anything. Link to comment Share on other sites More sharing options...
BenMerritt Posted February 27, 2019 Share Posted February 27, 2019 12 hours ago, ComputerMaster86 said: Do any of you guys get door jambs when you mull a fixed door with an hinged door? I am wondering if this is a bug in X11? Mulling a pair of doors tends to move the casing to a different location, which is a known issue. If you adjust the "Overlap Frame" amount on the mulled unit's Casing panel to match the "Reveal" option on the original door's Casing panel (but with the sign reversed), the doors should look exactly the same. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 27, 2019 Share Posted February 27, 2019 19 minutes ago, BenMerritt said: Mulling a pair of doors tends to move the casing to a different location, which is a known issue. If you adjust the "Overlap Frame" amount on the mulled unit's Casing panel to match the "Reveal" option on the original door's Casing panel (but with the sign reversed), the doors should look exactly the same. The bigger issue is the plan view where there seems to be no way to get the jamb to display for these mulled units. Link to comment Share on other sites More sharing options...
BenMerritt Posted February 27, 2019 Share Posted February 27, 2019 1 hour ago, Alaskan_Son said: The bigger issue is the plan view where there seems to be no way to get the jamb to display for these mulled units. Yep; looks like that stopped working in X11. I'm pretty sure I broke that, actually. I'll look into it today. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 27, 2019 Share Posted February 27, 2019 7 minutes ago, BenMerritt said: Yep; looks like that stopped working in X11. I'm pretty sure I broke that, actually. I'll look into it today. Way to own your mistake man!! Love it!!!! Link to comment Share on other sites More sharing options...
