Max3732 Posted February 26, 2019 Share Posted February 26, 2019 With Chief Architect 8 If I have a certain kind of furniture and I want to swap into a different style is there an easy way to do it? For example, if I have a square coffee table and have it where I want it in the floor plan as well as the colors and I want to change it to a circular one, is there a way to change the type? Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 27, 2019 Share Posted February 27, 2019 Modify your favorite symbols and once modified, place them into a custom library in one place. DJP Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 27, 2019 Share Posted February 27, 2019 Closest thing to what you've described is the Replace From Library tool in your Edit toolbar. Select the symbol you want to replace, click on the aforementioned tool, and then select the item you want to replace it WITH. It won't keep the "attributes" (as you say), but it gets you partway there. Link to comment Share on other sites More sharing options...
