Window apron
DavidRMiller1963
39 minutes ago, DavidRMiller1963 said:
Is there a way to change the profile of an interior window apron and also edit the size?
I do as Eric suggested above, but just FYI, the apron is an exact copy of any molding you apply to the sill except that is adjusted to match the thickness of your casing as well as the width of your casing (in combination with the sill) down to a minimum of 1" tall I believe..
