pgjacob Posted January 15, 2019 Share Posted January 15, 2019 HI All In a video walkthrough (link below) the under cabinet lights are flickering. These are simple point lights. Any suggestions? https://youtu.be/i2o3EN6Trwg thanks melissa Link to comment Share on other sites More sharing options...
Chopsaw Posted January 15, 2019 Share Posted January 15, 2019 Can you send that into tech support as Chief is aware of that issue and I thought they fixed it. Their solution at the time was to turn off shadows. Which is entirely unacceptable in my opinion. Curious what codec you are using ? Otherwise great video. Link to comment Share on other sites More sharing options...
pgjacob Posted January 15, 2019 Author Share Posted January 15, 2019 THanks Chopsaw I am using what CA recommended, XVID. I do have shadows turned on and I agree, shadows are a necessity. I will send in to tech support. The flickering completely ruins the video... melissa Link to comment Share on other sites More sharing options...
Chopsaw Posted January 15, 2019 Share Posted January 15, 2019 9 minutes ago, pgjacob said: I am using what CA recommended, XVID. Ok, same as I use but you seem to have a bit more of the rainbow on walls (not sure of the technical term) than I usually do. Maybe just the PBR as I have not done much of that yet. Link to comment Share on other sites More sharing options...
