studio Posted January 10, 2019 Share Posted January 10, 2019 I have tried several other packages and have had the same problem and am curious if I would with HDP? I flip houses, the house is already built and the sheetrock is up and finished, so I go in and measure the rooms with have inside to inside dimensions, none of the other package let you layout a room based on the inside to inside measurements. Is it possible with HDP? If so what do you have to change for it to function in this manner? Thx Link to comment Share on other sites More sharing options...
rlackore Posted January 10, 2019 Share Posted January 10, 2019 You've found the Chief Architect Premier forum. Home Designer Pro has it's own forum, where you might get a better answer. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 10, 2019 Share Posted January 10, 2019 3 hours ago, studio said: I have tried several other packages and have had the same problem and am curious if I would with HDP? I flip houses, the house is already built and the sheetrock is up and finished, so I go in and measure the rooms with have inside to inside dimensions, none of the other package let you layout a room based on the inside to inside measurements. Is it possible with HDP? If so what do you have to change for it to function in this manner? Thx Yes , you can set all dimensions to Surfaces instead of the Wall's Main Layer (framing)..... (How I work alot for Remodels) Generally HD Product questions are best asked over on Hometalk...same sign in and User name, etc. They had a special Sale price on till Jan.7 , not sure if they extended it? but you may still get it if you phone them? can't hurt to ask.... https://hometalk.chiefarchitect.com/ 1 Link to comment Share on other sites More sharing options...
