M-Ferioli Posted December 19, 2018 Share Posted December 19, 2018 I've noticed that the gap between the cabinet doors is different if I have and opening with double doors vs a partition to split the opening. Reveal is set to 1/16th inch and I'm using frameless full overlay for this example. With a partition I get about a 1/16th gap, without the partition I get a much smaller gap. Doesn't seem to be any setting for this unless I missed it. Either way I don't see any reason it should be different. Thanks! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 19, 2018 Share Posted December 19, 2018 I think you've stumbled on one of the only scenarios where that setting doesn't appear to make sense. The fact is that in the absence of a stile between the doors or a manually placed separation, Chief seems to default to a 1/64" gap between double doors. You might want 1/16" with your frameless full overlay, but would you want 3/8" with a 3/8" reveal or would you want a traditional face frame to have a huge gap between the doors? I suppose we could have a setting to control that reveal, but I'm about as picky as they come and I don't think I would ever personally care enough about that to warrant requesting anything different. Link to comment Share on other sites More sharing options...
M-Ferioli Posted December 19, 2018 Author Share Posted December 19, 2018 I noticed this while rendering some white cabinets. I couldn't figure out why the separation between some doors was hard to see in certain lighting while others stood out no problem. I'm not advocating for a user control but figured I'd ask just incase I was missing something. Seems like its just a case of some limited coding that could have been written better. Thanks for confirming I'm not crazy! Link to comment Share on other sites More sharing options...
MarkMc Posted December 19, 2018 Share Posted December 19, 2018 1 hour ago, M-Ferioli said: I'm not advocating for a user control but figured I'd ask just incase I was missing something. Seems like its just a case of some limited coding that could have been written better. You can adjust reveals using blank areas if it's important enough. I don't usually bother with that condition but worth knowing about. I've asked for independent control of reveals -not likely to happen. I only bother with it for tops of cabinets, ovens and really fussy clients. Adding blanks can have other consequences, notably in CAD details with doors turned off, it also affects a macro I use for a cabinet brand label. Cabinet on left is standard, the one in center has 1-9/16" blank area added. Link to comment Share on other sites More sharing options...
M-Ferioli Posted December 19, 2018 Author Share Posted December 19, 2018 smart! I may employ that tactic if it gets annoying. Thanks! Link to comment Share on other sites More sharing options...
