stephenbc Posted November 21, 2018 Share Posted November 21, 2018 When one selects a line (e.g. in 2D CAD view), the line turns red to indicate edit mode for that line. Where is the control for the display thickness of that editable line? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 21, 2018 Share Posted November 21, 2018 Thta's simply controlled by the line weight of that particular object. Link to comment Share on other sites More sharing options...
stephenbc Posted November 21, 2018 Author Share Posted November 21, 2018 Yes, you are correct, thanks. I was zoomed in so much I didn't think that a line weight of 2 should be that thick...but apparently, it is. Link to comment Share on other sites More sharing options...
Dermot Posted November 22, 2018 Share Posted November 22, 2018 Personally, I find it much easier and more accurate to edit objects with line weights turned off. You can toggle line weights on and off using a toolbar button, using the menus, or even setup a hotkey to do this. 1 Link to comment Share on other sites More sharing options...
