GeneDavis Posted November 8, 2018 Share Posted November 8, 2018 Access stairs to basement from service and mudroom level are a mess in this plan. If you've the time and are willing, show me how to clean them up. You'll note if examining the plan that I have a wall situation on the R of the stairs down to below, that I did as a stacked-on wall, and maybe that is the one causing the railing wall above to not generate as I want. The splits on the open-below rooms are to deal with two differing ceiling situations above, one framed flat, the other not there and framed by roof above. Sushko Mirror Lake Drive.plan Link to comment Share on other sites More sharing options...
AvoyeDesign Posted November 8, 2018 Share Posted November 8, 2018 Hi Gene, I had a quick look at your plan for you and marked up some areas of concern. Give that a go and see if it solves your issues. Sushko Mirror Lake Drive Markups.plan Link to comment Share on other sites More sharing options...
