Wall endcap
Mar_Vel
1 hour ago, Mar_Vel said:
Is there a setting to automatically have material (drywall) on the ends of a full height wing wall?
Thanks, Mark
I find that if the wing wall is internal (contained in a room) the drywall will wrap around the end of the wall.
If it is an external wing wall, you can draw a room around the end of the wall and define the room with no floor, no ceiling.
Thanks, Mark
Try re-drawing the Wall because it should happen automatically , but doesn't always as you have found out.
Or post a copy of your Plan in the q&A section of the forum for other to have a look for you.
(make sure the plan is closed in Chief when you attach it to your reply/post.)
