MarkMc Posted October 11, 2018 Share Posted October 11, 2018 Start new topic I noticed a request for grab bars that dimensioned properly and thought I had something some where. Attached plan has a few. They are really only one symbols but generated new block on resize. Have these set to center at 33" off floor, and label reads the width correctly based on center to center. Dimensions will snap to centers side to side and center in elevation. Change label, layer, and height off floor to suit in your library or in the object. In case you want to adapt any others- Started with a standard 24" grab bar, changed bounding box to 24" width, 0" height. Locked out height resize and set width resize to between the escutcheons. Offset vertical origin so it would dimension properly in elevation. grab bar door.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted October 12, 2018 Share Posted October 12, 2018 Thanks Mark , that sounds good and makes me wonder even more why CA's symbols can't measure to centers too.... The 0" high seems wrong but it works ? that's one I haven't seen before. M. Link to comment Share on other sites More sharing options...
jscussel Posted October 12, 2018 Share Posted October 12, 2018 Mark, The only Grab Bar that is dimensioned correctly is the 24" Bar. The 30", 36" and 42" are off center. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 12, 2018 Share Posted October 12, 2018 On 10/12/2018 at 4:21 PM, jscussel said: Mark, The only Grab Bar that is dimensioned correctly is the 24" Bar. The 30", 36" and 42" are off center. Expand Good catch but it appears to be only in plan view they aren't dimensioning accurately once stretched Link to comment Share on other sites More sharing options...
MarkMc Posted October 12, 2018 Author Share Posted October 12, 2018 On 10/12/2018 at 4:21 PM, jscussel said: Mark, The only Grab Bar that is dimensioned correctly is the 24" Bar. The 30", 36" and 42" are off center. Expand didn't notice that, guess you do need a separate one for each size, fixed while waiting for a flight. Only checked plan view for this. Need more you're on yer own grab bar door.plan grab bar door.plan Link to comment Share on other sites More sharing options...
