C to C Grab Bars
MarkMc
Start new topic
I noticed a request for grab bars that dimensioned properly and thought I had something some where. Attached plan has a few. They are really only one symbols but generated new block on resize. Have these set to center at 33" off floor, and label reads the width correctly based on center to center.
Dimensions will snap to centers side to side and center in elevation. 5bbfb3a58e049_Grabbars.thumb.png.d2268501dcc14566112a56122bc82358.png
Change label, layer, and height off floor to suit in your library or in the object.
In case you want to adapt any others-
Started with a standard 24" grab bar, changed bounding box to 24" width, 0" height. Locked out height resize and set width resize to between the escutcheons. Offset vertical origin so it would dimension properly in elevation.
grab bar door.plan
23 minutes ago, jscussel said:
Mark,
The only Grab Bar that is dimensioned correctly is the 24" Bar. The 30", 36" and 42" are off center.
Good catch but it appears to be only in plan view they aren't dimensioning accurately once stretched
35 minutes ago, jscussel said:
Mark,
didn't notice that, guess you do need a separate one for each size, fixed while waiting for a flight. Only checked plan view for this. Need more you're on yer own :)
grab bar door.plan
grab bar door.plan
    30186
    AshleyH
    AshleyH
