152431 Posted October 11, 2018 Share Posted October 11, 2018 Another question here: Am I able to change the layer sets on just the layout pages or do I have to send a bunch of different renderings of the same plan with different layer settings? Link to comment Share on other sites More sharing options...
MarkMc Posted October 11, 2018 Share Posted October 11, 2018 You don't say what version you're using-please fill out your signature which makes it easier to help. IF you are using X10 AND send a plan with plan view set to "None" you can change the layout box layerset. You can also change the layout box layerset for elevations and it works pretty well. OTOH IMO the easiest way to deal with plans in X10 is to use Plan Views. In prior versions you can change the layout box layerset for plans but it gets weird at time doing that for elevations views so I don't go there. I posted a short bit on Plan views recently There is a bit more to layouts than just that though so you may want to read up on them. Link to comment Share on other sites More sharing options...
