MN_JohnH Posted September 28, 2018 Share Posted September 28, 2018 I am trying to figure out how to move and position my plot lines independent of the house plan. I have a couple layers that I would like to move all at once, rotating and whatever. I have a JPEG layer with an areal view and then a cad layer with the topo lines that I have traced, Ultimately I will make those topo lines into a terrain to so I will have those additional layers that I would like to move all at the same time. I want to keep the house square in front of me but I need to move the land around to get the house positioned better. Is there a way to select by layer and select everything on a few layers so I can move them around? I can make them all into a block but the I can't make the block go behind the footprint of the house so I can't see the house as I am positioning the land. Link to comment Share on other sites More sharing options...
rlackore Posted September 28, 2018 Share Posted September 28, 2018 After you've blocked everything you want to move, double-click the block to open the CAD Block Specification dialog box, and then set the Line Style>Drawing Group value to 38-Back. This should send everything within the block to the very back so you can see the house footprint as you position the block. 1 Link to comment Share on other sites More sharing options...
MN_JohnH Posted September 28, 2018 Author Share Posted September 28, 2018 Wow, thanks! I figured it would be simple but I could not figure it out. Link to comment Share on other sites More sharing options...
