Doug_N Posted September 2, 2018 Share Posted September 2, 2018 I have noticed something strange. Well strange to me, maybe it makes sense but I can't see why. I want to make a cathedral ceiling, The eave facia is deeper than the gable fascia and when I look at an overall view this is what I see. Is there an easy fix for this? The attached file is just an experimental file that I was using to learn how to control roof and soffit features. Also to get roof framing to behave without excessive thinning. Test ceiling file.plan Link to comment Share on other sites More sharing options...
Doug_N Posted September 2, 2018 Author Share Posted September 2, 2018 Reads Eric's answer and then repeatedly bangs his head on the wall. Link to comment Share on other sites More sharing options...
Doug_N Posted September 2, 2018 Author Share Posted September 2, 2018 Thanks Eric for that simple fix. I can't begin to tell you how embarrassed I feel. Link to comment Share on other sites More sharing options...
Kaemingk Posted April 9, 2019 Share Posted April 9, 2019 I know this is an old topic but this fix didn't work for me. The gaps are only on my gable ends and they are the thickness of my roof structure. I don't want a closed soffit andI'm trying to have facia board turned on it's flat edge. I don't want any trim underneath it. I just want the siding to run up to the horizontal facia. I reduced the sub facia as small as it will go to no avail. What am I doing wrong? Also I turned off my trusses in this view so that it's evident that the siding does not reach the flat facia. Also I unchecked the sub-facia all together which did nothing as well. Link to comment Share on other sites More sharing options...
Kaemingk Posted April 9, 2019 Share Posted April 9, 2019 Ok, I'll make a new topic. I only want a facia at in an irregular orientation, no soffit. I would however draw it in a different way should it solve the problem.. Link to comment Share on other sites More sharing options...
