Have CAD blocks show on Foundation plan
TonyMM
Hi there,
I am needing to show the hold downs on the foundation page. I can add them manually in Layout but it would be nice if there was a way to be able to have them automatically show up on the Foundation layer from the Framing Layer. Any ideas?
Put them on a specific layer.  Then create a layer set that only displays that layer and use that layer set as the referenced layer for your foundation plan.
ps:  I also display the "Walls, Main Layer Only" in that referenced set.  This makes it easy to see where my shear walls need to be.
btw, this thread should have been posted in the Q&A Forum.
  • 2 weeks later...
I have created a lateral and HD anno set that is linked to same layer set and associated layers.
After I layout all of my HDs  and associated text on the floor plan then i just go to all off layer- turn on text HD and callouts HD- select and copy- move down floof level- paste hold position- make a few adjutments and done.
Repeat as needed for floor levels or views.
FYI- this method works well for chasing point loads down from roof to foundation.
