Chopsaw Posted August 3, 2018 Share Posted August 3, 2018 I am not sure I have tried this before but is it not possible to assign a new material to a Symbol during the Symbol creation process through the Materials tab of the Symbol DBX ? It just seems to ignore the input and sticks it into the User Library as it was. I thought maybe I pressed the wrong button but it would not put it into the library at all if I did. I usually paint things before creating the symbol so I know what it will look like but this was just one material and I did not need to see it, also would be much faster than painting. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 4, 2018 Share Posted August 4, 2018 This is a bug. It works if you FIRST select a material default and then pick another material. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 4, 2018 Author Share Posted August 4, 2018 Thanks Michael, I will add that to my tech report in case it helps in the diagnosis somehow. Link to comment Share on other sites More sharing options...
