srjbb97 Posted July 23, 2018 Share Posted July 23, 2018 Hi there! I am trying to get the roof to level out below the shed dormer if that makes sense... But the things I have tried haven't worked. Suggestions? And also in the 3D view a section of the house is just gone, why is that? Link to comment Share on other sites More sharing options...
srjbb97 Posted July 23, 2018 Author Share Posted July 23, 2018 1 minute ago, solver said: What is "level out"? do you want a lower sloped roof there? Best to post the plan file for questions like this. Yes for the roof, I want to start where the edge of the gable is under the dormer and cover the ceiling plane above the porch area. Attached the plan. Untitled 2.plan Link to comment Share on other sites More sharing options...
HumbleChief Posted July 23, 2018 Share Posted July 23, 2018 13 minutes ago, srjbb97 said: Yes for the roof, I want to start where the edge of the gable is under the dormer and cover the ceiling plane above the porch area. Attached the plan. Untitled 2.plan You can draw a manual roof plane where you want it and adjust slope/height to taste unless I'm missing something... Link to comment Share on other sites More sharing options...
HumbleChief Posted July 23, 2018 Share Posted July 23, 2018 1 minute ago, solver said: I did not see the problem with the space above the foundation wall looking quickly. Can't figure this out either. You can always drag the walls down in 3D but I don't know why those walls will not build the siding down to the top of the foundation. Link to comment Share on other sites More sharing options...
srjbb97 Posted July 23, 2018 Author Share Posted July 23, 2018 11 minutes ago, solver said: The dormer seems to be incorrect, so I deleted and redid. You can use a Full Return to auto build them. Is this porch roof like you want? I did not see the problem with the space above the foundation wall looking quickly. 8 minutes ago, HumbleChief said: Can't figure this out either. You can always drag the walls down in 3D but I don't know why those walls will not build the siding down to the top of the foundation. Yes, I will try the auto-return! Thank you! I have that space missing on another home plan I am currently working on as well. It has never done that before. Link to comment Share on other sites More sharing options...
srjbb97 Posted July 23, 2018 Author Share Posted July 23, 2018 7 minutes ago, solver said: It's your wall definition. Your siding is set to a 0" thickness. Make it correct to fix the problem. I noticed this on another plan recently -- one that was posted here or HomeTalk. Thank you guys for the help!! I appreciate it so much!! Link to comment Share on other sites More sharing options...
