Rescheck
RGWhite
Working with Rescheck and was wondering how you handle additions.  The addition will have it's own mini split system so therefore will not be mechanically tied to the house.  I did an as built and labeled the existing rooms "unconditioned" thinking it would not figured in the energy calc.  I did not put insulation in the existing walls.  The addition had all the insulation.  When I exported the plan to Rescheck it had all the walls and I could tell which ones were the addition by the insulation.  It was more work deleting the existing.  Is there a better way to export an addition so that only the windows, walls of the addition show on the recheck.
Model the existing building as is, must be conditioned space
Model the addition and any demising walls
Model the hvac for the existing building
Model the hvac for the addition
Model any garages if attached
Run the calculation.
