Customizing Textures
Designer1
I have a custom limestone block with running course.  I imported it to chief and the default setting for the texture image is 20 x 20.  In order for it to look accurate and realistic I have to change the size settings to 80 x 20.  Each time I apply the texture in a new plan I have to use to rainbow tool to change the ratio.  Is there a way to set it once and have the chief library remember that setting so I dont have to adjust it every time I use that material?
Thanks in advance!
Open the material in your user library by right clicking and set the scale and it should stay that way unless you adjust it but have it the way you want and do your adjusting in plan if necessary.
    30735
    EmersonGraceD
    EmersonGraceD
