decorators3 Posted June 27, 2018 Share Posted June 27, 2018 Hi I have attached my design (as it is so far) but I am standing still trying to figure out how to attach an open canopy idea. ( also attached) If you can give me some advice it would be helpful.. Thanks Levina Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 27, 2018 Share Posted June 27, 2018 Your forum for the software you use is Home Talk but since you have Home Designer Pro you can like Chief Premier users, just manually create your entry using available tools. What I recommend you do first is to draw the covered porch area using railing walls to demark its boundaries like any other space, mark the outer wall "Gable" and see if it will not build "automatically". If not then draw it manually. The gable truss can be drawn using soffits and slanted soffits reshaped to look like the truss parts. Many users here do not know what "Home Designer Pro" is or what it does and does not do. DJP Link to comment Share on other sites More sharing options...
decorators3 Posted June 27, 2018 Author Share Posted June 27, 2018 Ok Thank you so having chief architect 10 and home designer pro where should i post my questions.. Levina Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 27, 2018 Share Posted June 27, 2018 I posted a link to Home Talk above, it will take you to the Home Talk forum. DJP Link to comment Share on other sites More sharing options...
