WoodlandDesign Posted June 15, 2018 Share Posted June 15, 2018 I received a plan file from one of my builder clients that was created in Designer. For the most part it transferred to Chief but the plan sets seem to be missing their full menu. (Please see screenshot). Is anyone familiar with this and/or does anyone know the solution to obtaining the rest of the plan sets? I'm thinking there must be a reset option or similar.... Thanks in advance. -DG Link to comment Share on other sites More sharing options...
Chopsaw Posted June 15, 2018 Share Posted June 15, 2018 It appears you have 12 layer sets and 11 pages of layout that could potentially be a complete drawing set. Can you link back to the plan file from the layout views ? What do you suspect is missing ? Link to comment Share on other sites More sharing options...
WoodlandDesign Posted June 15, 2018 Author Share Posted June 15, 2018 I only get the default layer set when I link back from the layout pages. I want to be able to utilize, for example, the regular framing or roof plan sets but they don't exist without me creating them. I don't understand why they aren't in my drop down tab under Active Layer Set Control. I assume because I imported the plan from Designer that it has something to do with it. Does that make sense? Link to comment Share on other sites More sharing options...
WoodlandDesign Posted June 15, 2018 Author Share Posted June 15, 2018 But I'm using Chief doesn't that mean I should have them? Link to comment Share on other sites More sharing options...
Chopsaw Posted June 15, 2018 Share Posted June 15, 2018 You can create them or import them when using Chief. I think the last plan I got from Designer was all on the Default Layer. Did you get a layout file ? Link to comment Share on other sites More sharing options...
WoodlandDesign Posted June 15, 2018 Author Share Posted June 15, 2018 No layout file received from client but I just stumbled upon the solution. I went into the framing annotation set to check something and when I closed the DBX the missing default layer sets appeared in the Active Layer Sets drop down box! Very strange but glad I found the answer. Thanks for the input guys. Link to comment Share on other sites More sharing options...
