clearvuedesign Posted June 13, 2018 Share Posted June 13, 2018 No matter what I try I can not get the 2d symbol to aline with the 3d symbol... But I think I saw Mike B address this once. But I can't seem to find the thread. Link to comment Share on other sites More sharing options...
clearvuedesign Posted June 13, 2018 Author Share Posted June 13, 2018 Alaskan_Son is who I think posted on this subject... But I can't find his thread..... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 13, 2018 Share Posted June 13, 2018 If you are using X10 you need to set the symbol "y" origin to match the "y" size of the symbol. After doing that you might have to re-generate the 2D Block. I think prior versions are the same but I'm not sure. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 13, 2018 Share Posted June 13, 2018 Essentially, Vent Symbols are just a special class of Window Symbols. By default the origin is at the back of the Symbol when created but Windows Symbols snap to the front face of the wall so we have to adjust the "y" origin to compensate. I often think the adjustment should be a negative number but it actually needs to be positive. Link to comment Share on other sites More sharing options...
clearvuedesign Posted June 13, 2018 Author Share Posted June 13, 2018 Hi Joe, I tried that but it does not move the 2d block. This is the import file I used to make it. Smart Vent-1.plan Link to comment Share on other sites More sharing options...
clearvuedesign Posted June 13, 2018 Author Share Posted June 13, 2018 It looks great in 3d. I just can't get that 2d right!! Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 13, 2018 Share Posted June 13, 2018 I know I had a problem with custom window symbols before and it was a convoluted problem. Typically they get placed on the outside of the wall in plan view which is exactly what you are experiencing. I tried using a modified CAD Block and adjusting the origin of the CAB Block. Sadly that didn't work either. This is one that needs to be reported to CA Support. If you are still on X8 I think you are probably out of luck. The only solution at that point is to define your symbol as just an Architectural Block and manually place it in an "Pass Thru" opening. Link to comment Share on other sites More sharing options...
clearvuedesign Posted June 13, 2018 Author Share Posted June 13, 2018 I'm on X10 but for some reason, my profile opens correctly but it shows as x8 not sure why. Thank for the help Joe! I will give tech support a try... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 13, 2018 Share Posted June 13, 2018 Windows and their 2D blocks really kinda stink and they always have. Prior to X10 I started handling this by converting windows into normal symbols and then cutting away the wall layers using material regions and modified framing. If you are using X10 though, I would recommend converting to a normal symbol and then using the new Inserts Into Wall option. Link to comment Share on other sites More sharing options...
clearvuedesign Posted June 13, 2018 Author Share Posted June 13, 2018 I got it to work finally!! But know I need to know how to share it with guys.. lol Not sure if this helps but the I file did them in is attached.. Smart Vent-1.plan Link to comment Share on other sites More sharing options...
