Floor coming through the wall
QualicoreHomes
Hello again,
Can someone help me out with explaining the reason why the floor is coming through this wall.  I tried all the options I know such as changing the framing to "stop at ceiling below" or "go through floor below" and "Balloon through ceiling above" but none work.  I also tried changing that portion of the wall by selecting "Lower wall type if split by butting roof" but I can not master it to have it disappear.  I looked on the forum to see if there was a similar problem but the best I can do is change the shape of the walls so the siding becomes drywall instead of siding but the floor edge keeps peeking through.
Thanks in advance for your help!!
