BlueTree Posted May 11, 2018 Share Posted May 11, 2018 Working on the CAx9 Bathroom demonstration. getting near the end, notice the glass shower walls are piercing the adjoining wall. Cant pull it out to butt the wall. Any help in appreciated. Test_Bath_1.plan Link to comment Share on other sites More sharing options...
Chopsaw Posted May 11, 2018 Share Posted May 11, 2018 Have you tried the Edit Wall Layer Intersections tool ? Link to comment Share on other sites More sharing options...
BlueTree Posted May 11, 2018 Author Share Posted May 11, 2018 That worked for one the shower glass walls. The wall that adjoins at a corner not working. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 11, 2018 Share Posted May 11, 2018 Do you mean the break in the wall covering in the shower ? Everything else seems to be able to be fixed with the Intersections tool. You also have an irregular wall offset beside the tub between the painting and window. Link to comment Share on other sites More sharing options...
BlueTree Posted May 11, 2018 Author Share Posted May 11, 2018 k, Chopsaw. Think I got it fixed. Thanks a bunch for your help from the the Great White North. Link to comment Share on other sites More sharing options...
BlueTree Posted May 11, 2018 Author Share Posted May 11, 2018 Test_Bath_1.plan Link to comment Share on other sites More sharing options...
Chopsaw Posted May 11, 2018 Share Posted May 11, 2018 Keep up the great work, love the wall mural, but that is a pretty tricky stall door you designed. Link to comment Share on other sites More sharing options...
BlueTree Posted May 11, 2018 Author Share Posted May 11, 2018 Thanks. Following along with the demo vids on youtube. I'm a newbie. Link to comment Share on other sites More sharing options...
cv2702 Posted May 11, 2018 Share Posted May 11, 2018 I noticed they're no slop in the shower and no means to keep water from pouring over the wood floor. Hope this is "in progress" Also, in PBR, the glass shower walls and door are totally transparent, in both PBR and standard views, even if the definition is tempered glass. The reflection is not realistic as the walls are invisible. Is it just me? I seem to remember in previous versions that tempered showed a slight tint in standard view at least. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 11, 2018 Share Posted May 11, 2018 2 minutes ago, cv2702 said: I seem to remember in previous versions that tempered showed a slight tint in standard view at least. Yes that threw me off as well and I thought it was standard glass until I checked. Not totally transparent but certainly not how I remember it from before. Link to comment Share on other sites More sharing options...
