Richard_Morrison Posted May 11, 2018 Share Posted May 11, 2018 Thought I'd see if I am missing any time-saving steps for revising/replacing CAD details. Let's say I've got a detail that I need to revise, located in a folder in the User Library. Currently, I have to 1) place the detail, 2) explode it, 3) revise it, 4) re-block it and save to bottom level of User Library with same name, 5) Move library block with cut/paste to original folder, 6) Delete old detail with same name. Any way to save a step or two or is that as good as it gets? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 11, 2018 Share Posted May 11, 2018 There are a couple other methods of storing those CAD Details that would allow for less extra moves... 1. Use CAD Block Management to store some of those CAD Details (especially those that get edited often). This way you only have to drop into plan, explode, modify, rename to original name, and you're done. The biggest downside to this method is that it CAN cause some otherwise unnecessary plan size bloat. 2. You can use a CAD Block warehouse plan and either store the CAD Blocks in CAD Details, in CAD Block Management, or right there in Plan View. The beauty of this method is that you can optionally link these CAD Blocks to layout files so that changes are essentially global; otherwise, you just copy and paste. No futzing around with all the extra steps either. If you want to edit the block you just edit it and leave it sitting right where it is. As far as storing in the library...Yes, I think you're doing about the best you can do. It sure would be nice if we could simply right click and "Edit CAD Block" wouldn't it? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 11, 2018 Share Posted May 11, 2018 Link to comment Share on other sites More sharing options...
Richard_Morrison Posted May 11, 2018 Author Share Posted May 11, 2018 I've generally been storing most details -- one detail per CAD detail view -- in the Detail Management Section of the Layout, which maintains the scale of the details, as well as automatically labels the detail when sent to layout pages. But I keep things like text blocks and notes in the library for placing directly on the layout pages, as well as backup copies of the details. I've often wondered if having multiple similar details in a single CAD detail causes less bloat, though. Link to comment Share on other sites More sharing options...
AvoyeDesign Posted May 11, 2018 Share Posted May 11, 2018 1 hour ago, Alaskan_Son said: And to comment on your quote of my suggestion, repeat several times for the same cad block when you realize you missed something. Link to comment Share on other sites More sharing options...
