basilbabaa Posted May 11, 2018 Share Posted May 11, 2018 Is there a way to change the layer of labels. I can change the layer of a meter base, but am unable to change the layer that label is associated with so it corresponds with the correct layer that an object is associated with. For instance I have a Breaker Panel that comes in as an interior fixture, and I change its layer to electrical, but the label does not move to the electrical labels layer. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 11, 2018 Share Posted May 11, 2018 Here's my advice. Instead of simply moving the meter base to the electrical layer, make it an actual electrical object. Drop it into the plan, click Tools>Symbol>Convert To Symbol, select Advanced Options, and then set the various parameter like you want them. From that point forward the labels will be on your desired layer, it will get added to the correct schedule, you can connect electrical to it, etc. etc. Link to comment Share on other sites More sharing options...
