Designer100 Posted May 2, 2018 Share Posted May 2, 2018 Connot get porch railing to go all the way to the round column. Any suggestions. 3 ft of porch is uncovered. Thanks for any help someone can give. Newell Chief x10 newell@newellcheatheam.com VU Remodeling New 02.2018.zip Link to comment Share on other sites More sharing options...
Chopsaw Posted May 2, 2018 Share Posted May 2, 2018 Reduce the bounding box size of the column to the diameter of the round part and you should be good. 1 Link to comment Share on other sites More sharing options...
Designer100 Posted May 3, 2018 Author Share Posted May 3, 2018 Heres the zip file. VU Remodeling New 02.2018.zip Link to comment Share on other sites More sharing options...
Designer100 Posted May 4, 2018 Author Share Posted May 4, 2018 boundry box arond the library post would not go smaller. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 4, 2018 Share Posted May 4, 2018 Is that what you are after ? The brown rail needs to attach and butt into the white columns ? Zip file is empty Link to comment Share on other sites More sharing options...
Chopsaw Posted May 4, 2018 Share Posted May 4, 2018 Actually you don't even have to change the bounding box unless you are using the columns as Newels. Just drag the railing to the correct position. Link to comment Share on other sites More sharing options...
