Skip_D Posted April 26, 2018 Share Posted April 26, 2018 I can't believe I'm asking this because it must be something obvious that I'm not seeing ... My deck is not showing. If I define the room as a bedroom, for instance, it appears with that default floor, but defined as a deck it disappears. I tried drawing a deck off the other side of the home to test, and same deal, no deck showing. The room is 'closed' since I can select it. Even with 'all on set' layer, nothing. Thanks, George X9 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 26, 2018 Share Posted April 26, 2018 are the deck framing layers on? and did you frame it. Link to comment Share on other sites More sharing options...
solver Posted April 26, 2018 Share Posted April 26, 2018 18 minutes ago, Skip_D said: Even with 'all on set' layer, nothing. Make sure all layers are on in the All On set. Post your plan for the best answers. Link to comment Share on other sites More sharing options...
Skip_D Posted April 26, 2018 Author Share Posted April 26, 2018 good point on the All On Layer Set ... I had some items off but still not the solution on this one. I had not framed it and automatic generate deck framing was turned off, that fixed it, thanks! Link to comment Share on other sites More sharing options...
