dshall Posted April 26, 2018 Share Posted April 26, 2018 I use midspan bearing trusses very very very rarely. It is typically not necessary. As far as brace lateral walls every 25' , that is if the prescriptive method is being used. Since every project I do (99.997%) need to be engineered, I do not need to abide by the perspective method. Link to comment Share on other sites More sharing options...
rlackore Posted April 26, 2018 Share Posted April 26, 2018 Just now, dshall said: I use midspan bearing trusses very very very rarely. It is typically not necessary. As far as brace lateral walls every 25' , that is if the prescriptive method is being used. Since every project I do (99.997%) need to be engineered, I do not need to abide by the perspective method. I agree about the trusses. The prescriptive method rarely works for me either - too many large punched openings and expansive clear floor areas - so it's ASCE Methods 1 or 2 for most of my projects. Luckily I don't have to deal with seismic in my area, though I'm often in Exposure Cat C due to lakefront lots and a long fetch over open water. Link to comment Share on other sites More sharing options...
