Freize Boards
sdpatt
I had a go at your freeze problem and got it working in x 10  but was a bit tricky I would give your wall asbuilt layer like bricks and render so yo can see if they are facing the right way as they are mixed up because the were not drawn clock wise , also those complicate walls on the lower story are giving chief a hard time to start with I would delete some of them and replace with soffits so the walls are smooth from lower to first floor also I think it helps if you give the roof a bit more over hang like 14 “
i have all my previse versions of chief but are missing my key code to x6 so can’t send  a file with it working
you may be better getting that bit working with molding lines and just push on with rest of your roof as it is tricky to trouble shoot
