Aqua76 Posted April 23, 2018 Share Posted April 23, 2018 Hi there! I am having hard time to model the attached contemporary house. I am try to model it with steel framing. It is impossible to connect wall and roof seamless. Any advice or tutorial highly appreciated. thank you. Seko Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 23, 2018 Share Posted April 23, 2018 I would personally do that with primitives...probably a polyline solid or a solid with the structural components tucked neatly inside. Link to comment Share on other sites More sharing options...
stephanswim Posted April 23, 2018 Share Posted April 23, 2018 Have you tried doing the walls as a gambrel roof? I set the pitch of the lower roof at 89 degrees (CA doesn't allow a 90 degree pitch). You will probably have to experiment with it a little bit and fool around with baseline, ridge, and fascia heights, but you can still come close. Good Luck! Steve Link to comment Share on other sites More sharing options...
rlackore Posted April 23, 2018 Share Posted April 23, 2018 Maybe I misunderstand the intent, but I think it can be done with normal roof planes: roof.plan Link to comment Share on other sites More sharing options...
Aqua76 Posted April 24, 2018 Author Share Posted April 24, 2018 16 hours ago, rlackore said: Maybe I misunderstand the intent, but I think it can be done with normal roof planes: roof.plan Did you do it with automatic settings? Could you please send me the details of this set up? thank you for your help! appreciated! Link to comment Share on other sites More sharing options...
rlackore Posted April 24, 2018 Share Posted April 24, 2018 2 hours ago, Aqua76 said: Could you please send me the details of this set up? My first post has the plan file attached. Download it and you can dig into the roof settings. 1 Link to comment Share on other sites More sharing options...
Aqua76 Posted April 25, 2018 Author Share Posted April 25, 2018 19 hours ago, rlackore said: My first post has the plan file attached. Download it and you can dig into the roof settings. COuld you please post x8 version. thanks for your help! Link to comment Share on other sites More sharing options...
rlackore Posted April 25, 2018 Share Posted April 25, 2018 4 hours ago, Aqua76 said: COuld you please post x8 version. No, sorry. I'm on X10, and I don't keep previous versions of the software installed on my machine. I suggest you fill out your signature with the version of Chief you are using - that way I would have known from the start that you were running X8. Anyway, maybe these roof settings will help: 1 Link to comment Share on other sites More sharing options...
Aqua76 Posted April 27, 2018 Author Share Posted April 27, 2018 thank you all! Link to comment Share on other sites More sharing options...
