turn off attic walls
EconBlueprints
Attic walls keep automatically generating and I don't want the to do that.  I click on the wall, uncheck the "attic wall" box in the specifications , but then it just pops back up again.
How can they be turned off and not allowed to automatically generate themselves?
Thanks in advance.
Lane
They can be turned on or off (visible or invisible) in "Layer Display Options - Walls, Attic". If you do not want them to auto-generate there is a setting in 3D Defaults to have them auto-generate (set that way by default as you have seen) or to not generate at all, which then means that you will have to manually draw all Attic Walls yourself.
