taco117 Posted August 8, 2014 Share Posted August 8, 2014 using the soffit tool to create a trey ceiling, however on the floor plan it does not seem to show a "clean connection". I have used this in previous versions that seemed to create a cleaner connection and did not show each soffit generated. Is there a setting that can be changed to not show the lines between 2 soffits? Any suggestions? Using X6 windows 8.1 (BOO) xps8700 I7 Link to comment Share on other sites More sharing options...
tommy1 Posted August 8, 2014 Share Posted August 8, 2014 Turning off cabinet module lines in the layer display will solve most of your problems. The soffit is a cabinet tool. Link to comment Share on other sites More sharing options...
taco117 Posted August 8, 2014 Author Share Posted August 8, 2014 That solved it Tommy, Thanks. I had looked for something like that in layers and did not see it. Lance Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 9, 2014 Share Posted August 9, 2014 To me it looks like the front corners don't meet in the corners, adjust the center soffit so that it meets with the right soffit right in the front corner and they will join correctly. Link to comment Share on other sites More sharing options...
