VisualDandD Posted March 28, 2018 Share Posted March 28, 2018 Noticed this today. x10 GTX970 card 32gb ram i4790k processor...etc 3dconnection 3d mouse I had 3 or 4 3d view open and using standard render technique. I tried it with other rendering methods and was similar. Using 3d mouse to navigate was a little choppy. If I left clicked the mouse, it would navigate with zero lag. Anyone ever notice this https://youtu.be/DJbWYZUM_lE Link to comment Share on other sites More sharing options...
VisualDandD Posted March 29, 2018 Author Share Posted March 29, 2018 Bump...Anyone else use a 3d mouse and see this same effect? Link to comment Share on other sites More sharing options...
Smn842 Posted March 31, 2018 Share Posted March 31, 2018 Do you have the 2D plan visible in another window with the camera on the same level as the 3D view? If so then this may well be the issue I reported several times over the last couple of years, first when I purchased HD Pro and then again after upgrading to Chief Architect Premier. I noticed that whether or not the camera symbol is visible in the 2D plan, if both the 3D and 2D views are on the same level then the 3D view speed is greatly impacted as it appears for every movement the 2D plan is being recalculated and/or redrawn. The solution is to move the camera up or down a level or hold the mouse down in the 3D window which stops updates in the 2D plan. Before X10 that had the disadvantage of turning off lights but now with the higher light limit that's not an issue. Perhaps I should report again, but I posted it in the Home Designer suggestions forum here and the second time after buying Chief via email and heard nothing back. Link to comment Share on other sites More sharing options...
VisualDandD Posted March 31, 2018 Author Share Posted March 31, 2018 Thanks for the reply. I was beginning to think I might be the only one. I'll have to see if that is what is causing it. I always have multiple views open between monitors so that could likely be the case. Does it do it if you turn off camera labels in the 2D view? Link to comment Share on other sites More sharing options...
Smn842 Posted April 1, 2018 Share Posted April 1, 2018 12 hours ago, VisualDandD said: Does it do it if you turn off camera labels in the 2D view? Yes it still does the same for me no matter how I hide the camera from the 2D plan. I've just got into the habit of moving the 3D view to a different floor level to avoid the issue. Link to comment Share on other sites More sharing options...
