dskogg Posted March 28, 2018 Share Posted March 28, 2018 I have a vaulted main floor abutting a 2nd floor, i have selected roof cuts wall at bottom for upper wall but it still is showing siding and an opening for floor joists, what am i doing wrong? Link to comment Share on other sites More sharing options...
dskogg Posted March 28, 2018 Author Share Posted March 28, 2018 144 macewan park close nw as built.zip Link to comment Share on other sites More sharing options...
dskogg Posted March 28, 2018 Author Share Posted March 28, 2018 thanks eric, i did what you said and pulled roof planes away and snapped back and nothing changed. Link to comment Share on other sites More sharing options...
dskogg Posted March 28, 2018 Author Share Posted March 28, 2018 eric i did exactly what you did with no results...could i have different settings? I spoke to ca and they said to add a polyline solid to fix this. Link to comment Share on other sites More sharing options...
dskogg Posted March 28, 2018 Author Share Posted March 28, 2018 Thanks eric, this works, i still do not know how you can do this and i can not. I tried a sample plan and the same thing happened? And also chief told me there was no solution other than polyline solids etc. Link to comment Share on other sites More sharing options...
dshall Posted March 28, 2018 Share Posted March 28, 2018 Just now, dskogg said: Thanks eric, this works, i still do not know how you can do this and i can not. I tried a sample plan and the same thing happened? And also chief told me there was no solution other than polyline solids etc. part of your problem was your walls did to line up, hence the roof snapping was not working. 1 Link to comment Share on other sites More sharing options...
dskogg Posted March 28, 2018 Author Share Posted March 28, 2018 i lined up the main framing layer, but i have the build and dimension set to the exterior of sheathing...is this the problem? Link to comment Share on other sites More sharing options...
dskogg Posted March 28, 2018 Author Share Posted March 28, 2018 here is a screen shot of both plans...exactly the same dimensions for walls as eric's...still does not work. There must be something else? Link to comment Share on other sites More sharing options...
dshall Posted March 28, 2018 Share Posted March 28, 2018 I opened plan, selected two roof planes and moved up a level (for no reason), I selected wall removed cut wall at bottom, noticed that the wall was not in line with wall below, hit the button to align, then select to roof edges and moved them against wall, they auto snapped in place, plan fixed. I am assuming Eric did the same thing, but he did not mention he aligned the walls. 1 Link to comment Share on other sites More sharing options...
dskogg Posted March 28, 2018 Author Share Posted March 28, 2018 i tried both the wall align tool selecting upper wall and align below and also adjusted upper wall so the studs lined up. The walls are different, upper has siding and 3/8" sheathing, the lower 1/2" drywall. The upper main layer is set to the sheathing. Pulled walls away and snapped back to upper wall and still does not work. Link to comment Share on other sites More sharing options...
dskogg Posted March 28, 2018 Author Share Posted March 28, 2018 Thanks for helping guys, i did not have the check mark lower wall split by abutting roof...i missed in on video as it was dark on bottom of vid.. Have a great day... Link to comment Share on other sites More sharing options...
dskogg Posted March 28, 2018 Author Share Posted March 28, 2018 Link to comment Share on other sites More sharing options...
