jenmarsch Posted March 27, 2018 Share Posted March 27, 2018 I'm trying to create a lanai on the second floor. I did this with creating an exterior wall and putting arched openings in it. but when I addd the railing piece, the arch disappears and changes the opening to the railing opening. How do I marry the two? This is for a Mediterranean style home Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 27, 2018 Share Posted March 27, 2018 To answer the question, Create the Arched Openings Create the Railing Walls off to the side Open the Railing Walls dbx and check "No Room Definition" Move the Railing Walls into the Openings. 1 Link to comment Share on other sites More sharing options...
jenmarsch Posted April 4, 2018 Author Share Posted April 4, 2018 On 3/27/2018 at 2:46 PM, Joe_Carrick said: To answer the question, Create the Arched Openings Create the Railing Walls off to the side Open the Railing Walls dbx and check "No Room Definition" Move the Railing Walls into the Openings. Thank you , I will try this, I actually found where you had created valances, I did that to start with, not sure I like the look, I'll try this next. Link to comment Share on other sites More sharing options...
