Arch in Chief?
Designer1
Does anyone know if chiefs doorway tool is capable of drawing a round horseshoe arch?  Ive tried the full arch where the circumference of the arch reaches all the way to the ground width of the doorway without any success.  I also tried the archs circumference only extending beyond the width of the doorway width at the top and it wouldnt work either.  Heres a link with many different variations of the arch Im speaking about.
https://www.bing.com/images/search?q=horsehoe+arch&FORM=HDRSC2
Any ideas?
It's possible to get close to your pictured doorways with an arched doorway and a round pass-through on top.  I'm sure if you play around with the profiles you could probably get closer to your end product.  Make sure to delete the casing or the software will build it across the opening.
    30693
    mikedanderton
    mikedanderton
