Build New Floor won't work
ChiefUserAndyGa
When I select the Build- Floor -Build New Floor button I do not get the pop up pictured below (screen shot of a help video). After doing this if I click on my plan I get the same ping sound you get if you leave a dialogue box open.
I have run the plan check to make sure that there are no gaps in the walls but it was of no help.
Any ideas?
After you hit Build new Floor>etc........ Minimize Suite and see if the Dialog Box (DBX) is hiding behind the Main Window , which can happen if you click the main window making it the "Focus" for Windows. You can also check the taskbar and see if there is a second Icon (which maybe Flashing)
