Slab shows through foundation wall
mbdesigns
    30736
    hhh8087
    hhh8087
  • Similar Content
    • By j2narchitecture
      Hello.
      My basement slab is not showing in the cross section nor the 3D overviews.
      I have looked to see if I maybe have a layer turned off, but I do not see any.
      Link to plan is below.
      Any feedback is appreciated.
      TIA
      PLAN FILE
    • By AKnightClark
      Brand new user here! First question: Is there a specific order in which the tutorial videos should be watched to learn with a better A to Z process? I'm watching a ton, but they are not in a helpful order, so I'm taking 2 steps forward, 3 steps back, making error that I have to correct, etc.
      As for this particular topic, are there specific tutorials for creating a slab foundation that extends over a sloped terrain? I'm looking to make the footers, foundation walls, and slab. I've attached a screenshot from a CA video (unrelated) that shows the end result I'm looking for, as well as my work showing a floating slab.
    • By MN_JohnH
      I am wondering how I can set up my foundation walls and main floor so that I can have a slab on one part and a framed floor on the other that flush out at the same level.
      But I would like the top of the ICF foundation walls to have a double sill plate with the concrete poured inside of that where the slab is and the other side would have accommodations for the framing to come out at the same height. I have a simple plan attached and some cross section details of how the top of foundation wall would look.
      I know I can just build it with the slab at the same level as the house and then just have these detail drawings included in the plan but I am wondering if there is a way to actually have Chief build it this way?
      plan.plan
    • By TrimbachDesign
      Hello Chief friends,
      I've been struggling and searching this topic but cannot seem to come up with the information that I am looking for. Basically, I have a sloping site and want to draw the uphill stemwall (top) 2'0" higher than the downhill wall. The floor system will ledger off the uphill wall, and the uphill stemwall top should finish about 2'0" higher than subfloor elevation. Wood wall framing will then be 2'0" shorter on this uphill side. Additionally, I'll be using some retaining walls extending off of the foundation to retain the up hill fill material.
      I was able to "drag up" the top of the stem walls on the uphill wall to gain this two feet of elevation. However, there are all sorts of issues with wall intersections that I cannot seem to clean up. I think that what I am after is forcing the taller wall to run through, but I can't seem to force that in my foundation drawing or 3d view. There has to be a better way... Also, now the subfloor and some trim is sticking through the stem wall.
      I'm running x12 on MacOSX.
      Appreciate any help you all can provide!
      Thanks,
      Austin
    • By lucratect
      In my plan I need most of the foundation to be a monolithic slab except in areas where there are pipes such as the bathroom.  I am trying to figure out how to cut a hole in a foundation that I have generated in CA with the foundation tool, but when I try the "slab hole with footing" and the "Hole in floor platform" tools I get errors. "could not create hole in floor platform" and "a slab hole must be placed inside a slab".
      To elaborate on the foundation, it will be piers 4ft into the ground then a normal monolithic slab and footings will be poured on top of the piers.  The footings and slab will sit about 24" above the existing terrain where the piers tops also are.  The soil cap will be course gravel and basecourse on which the slab will be poured.  The bathrooms and other rooms with piping will be to the outside of the building and there will be a crawlspace below those areas to service pipes.
      I am hoping someone has experience with this and can help me.  I've scoured the forums and spent hours in CA to no avail!
