sweetmelissa Posted March 8, 2018 Share Posted March 8, 2018 I have a plan drawn and now am going back to change roof/ceiling type so it is more accurate. I read that you can build a roof and then remove the ceiling to get the effect, which I did and somehow I made it work, but now I cant replicate it. It will be a gable roof with 8 on 12 pitch. Room height will be 144". In full perspective view it looks right, but when I do an elevation of the wall it appears to have a flat ceiling and in the floor camera view the top part of the wall is missing as I've shown in the pic attached. Help would be much appreciated! Hope I explained enough. I don't know all the technical terms. My husband is the builder, I just draw the cabinets... and I'm still learning. Link to comment Share on other sites More sharing options...
sweetmelissa Posted March 8, 2018 Author Share Posted March 8, 2018 Ok, go it... What about the floor elevation? Should I be able to show the change in that mode? I've attached the pic where I did, but now can't. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 8, 2018 Share Posted March 8, 2018 11 minutes ago, sweetmelissa said: Ok, go it... What about the floor elevation? Should I be able to show the change in that mode? I've attached the pic where I did, but now can't. I'm not sure what you mean ? what is wrong with that Wall Elevation View ? ( except for Hood out the roof ) A Cross Section/Elevation will look different from a Wall Elevation , you may have the Roof Planes off in Wall Elevation but on in Cross Section/Elevation View though. Vies are all about the Active Display Options (ALDO) and what you see and don't see in any particular View. you can use Windows Snipping Tool to take Screen Images , see my Signature for how. The KB Article on Cathedral Ceiling just in case. https://www.chiefarchitect.com/support/article/KB-00471/creating-a-cathedral-ceiling.html Link to comment Share on other sites More sharing options...
sweetmelissa Posted March 8, 2018 Author Share Posted March 8, 2018 1 minute ago, Kbird1 said: I'm not sure what you mean ? Sorry to be confusing. I created this, went back and made some changes and then was unable to recreate this elevation view. I took the pic of the screen with my phone earlier and texted it to someone which is why I have the pic. Again, everytime I do a wall elevation it appears flat and you cant see half of the hood. You are differentiating between elevation and wall elevation which I'm not sure what you mean. If it's too hard to figure out what my problem is (except my obvious lack of experience), it's fine... I will keep reading and try to figure it out. Thank you. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 8, 2018 Share Posted March 8, 2018 They are two different Views (cameras) , so like the Full and Floor Camera, you may see Different things or even Past the Wall in question to other parts of the house depending on the Camera placement and the BackClip Distance. which camera you use will depend on what you want to achieve in the View.... if looking at Cabinets a Wall Elevation is Useful but sometime things like Electrical and Sloped Ceilings don't show , think of it like the Floor Camera, so use a Section Camera instead..... you may have found a Bug with the Hood too...post the plan and let someone look.... Also, it's good to have your Forum Signature filled in please, especially with the Software Version, and of course a Name is nice too ..............see mine below in Blue for how to do that. If you don't see my Signature then you have them turned off for the Forum (Toggle it on above where you make your Signature or are perhaps you are on the CA Mobile WebSite? Link to comment Share on other sites More sharing options...
sweetmelissa Posted March 8, 2018 Author Share Posted March 8, 2018 I added a signature for your viewing pleasure I was finally able to do what I was trying to do. I created a gable roof over the room, got rid of the ceiling, then changed absolute ceiling height to be approx 5" higher than what the pitched height should be. So, then when I created a wall elevation, it now shows it accurately. I'll fix the hood. Thank you for your indirect help... sorry to confuse you... which you probably still are! Link to comment Share on other sites More sharing options...
sweetmelissa Posted March 8, 2018 Author Share Posted March 8, 2018 I added a signature, I promise... maybe it will show up after I log out and then back in. Nice to meet you both. Link to comment Share on other sites More sharing options...
sweetmelissa Posted March 8, 2018 Author Share Posted March 8, 2018 They are in the process of widening HWY 98 right now to help with traffic. It just gets busier and busier every year. Come in October/November... Link to comment Share on other sites More sharing options...
