Jeanineb Posted August 4, 2014 Share Posted August 4, 2014 I was in the middle of a rendering ray trace today when saddening my new (1 month) computer crashed. When I started it back up I tried to open CA and an error message popped up that the "material.dat file is missing" and would open?! Any ideas? Is there a diagnostic tool within the support center for the program? I have a project deadline I am working on :-( Link to comment Share on other sites More sharing options...
jcaffee Posted August 4, 2014 Share Posted August 4, 2014 Try a System Restore within Windows using your most recent restore point. jon Link to comment Share on other sites More sharing options...
lbuttery Posted August 4, 2014 Share Posted August 4, 2014 Hmmm, I just checked mine and it is a very small file - around 14 KB I don't remember what it does ??? its possible you may need to re-install Chief but If no one has a solution you should check with CA's tech support first they open 6 AM Pacific Lew Link to comment Share on other sites More sharing options...
lbuttery Posted August 4, 2014 Share Posted August 4, 2014 MATERIAL - Copy.ziptry to use this one attached place it in the X6 folder on the C: drive under Program files Lew Link to comment Share on other sites More sharing options...
KilgoreTrout Posted August 4, 2014 Share Posted August 4, 2014 I would not trust Lew's file to solve your problems. Plus it's Lew so you never know if he's going to be passing around a virus or something. I would either do the system restore or reinstall Chief. If all else fails, call tech support. Link to comment Share on other sites More sharing options...
lbuttery Posted August 4, 2014 Share Posted August 4, 2014 yeah, I do have an itch that won't go away Lew Link to comment Share on other sites More sharing options...
