DavidJPotter
Chief Architect Help, Now!
Instant Chief Architect Software Help.
Don't even leave your home or office.
Your broadband Internet connection is all you need.
We will work on them together using reliable, secure, easy to use internet desktop sharing technology.
Nothing must be permanently installed.
Nothing to set up or change, just communicate and get answers, solutions and HELP now.
Call or email me today for a session appointment. Reasonable hourly rates for service when you need it.
Austin, Texas is next door via the internet!!
I have been teaching seminars in Texas and New Mexico in 2004-2005 and have been tutoring over the internet since 1999
I have Chief Versions 7 - X10 as well as all Home Designer versions 7-2018 consumer products on my PC to serve your needs.
I need tutoring. The link does not seem to lead to anything. New to CA and this forum.
5 minutes ago, solver said:
What link? David has his email, website and phone number listed.
This is the one that's not working...
On 2/8/2018 at 2:14 PM, DavidJPotter said:
Thanks, Michael, I used to also own a ".net" domain, now I just own a ".com" so that embedded link was to the same page on a domain that I no longer use, it is fixed now, thanks for bringing that to my attention!
You're welcome.
Interested in setting up a session with you to:
  1. Complete exterior - have a couple of challenging wall issues at offset roof line at the big window wall with the roof overhang
  2. Get some guidance on preparing my floor plans and elevations
  3. Get the look I want.  In lieu of brick, I would like a stone surface with a wainscoat in some areas
  4. I have the survey and site plan in .dwg format.  I'd like help dropping the house onto the site plan so I can properly site the house to properly capture the views.  I know where it is to be placed on the site, I just need assistance doing it.
  5. Get help with doing the wall sections so that the wall finishes stop 6" above the finish grade.  At about 8'100 feet in Tabernash, CO, the frost depth of cover for the footings is 60"
  6. Using version X9
  7. My name is Bruce Tonilas, email is bruce.tonilas@comcast.net, and phone is 303-941-1330
HomeDesign-2_story_rev6.plan
My contact information is displayed as part of my posts at the bottom (phone, email, website and tutoring services) which you are welcome to use and peruse. My online help scheduling, pricing, and other data can be read here, which you should carefully read. When you are ready, please request an appointment time on the indicated days and hours and I will then confirm that request into an agreed upon appointment provided your request does not conflict with another client' confirmed appointment: http://djpdesigns.com/tutoring.html
Thanks David.  Will email you shortly to schedule a session.  Attached is my current file.  I changed the roof design to allow for easier construction and thus solved some of my problems.  Would like to work with you using the attached file.  It would not send via normal email.
HomeDesign-2_story_rev7.plan
    28146
    JonasN
    JonasN
  • Similar Content
    • By Designers_Ink
      Designer's Ink is a full-service building design firm based out of Stillwater, Oklahoma; however, we have worked on projects in 27 different states and 5 different countries.  We have been in business since 1993 and have 5 designers and draftsmen on staff to serve you.  We specialize in creating stunning 3D models of your building project so you can see exactly what the building will look like before you build.  This significantly reduces the costs of change orders during construction.  Many of our clients have told us they saved more in construction costs using our services than they paid for our services due to reduced change orders and value engineering during the design.
      Once your 3D model is completed, we then produce easy to read construction documents.   We take a lot of pride in our construction documents which we customize for each client's specific needs.  Our goal is to produce our construction documents in such a way that the folks on the ground building the project have everything they need, and in a format they can use efficiently.
      With over half of our clients being from out of state, we have been working remotely with clients for years.  With the current restrictions caused by the COVID-19 pandemic, already having a system in place to communicate with our clients remotely is essential.  We have been using our system for years, so we know it works well.  We also offer one-on-one tutoring services for both Chief Architect and Home Designer Pro.  We have been using Chief Architect for 16 years.
      Please take a moment to look at our website at www.designersink.us for more information about our company.  If you would like to set up a free, no-obligation initial consultation, contact us to schedule a time that works for you.  We look forward to EXCEEDING your expectations.
      Jeff Dillon - Owner / Designer
    • By tlconstruct
      Hi guys, I'm new here and pretty new to Chief Architect. I have Home Designer Suite 2020, not the Premier version. I'm a graphic designer, just working up plans for a builder to show his concepts to clients. I'm having problems with a shed roof. I've looked up a bunch of videos and steps on how to do it, but it's not coming out quite right. I'll attach images.
      I have the 2nd floor height set to 2 feet, because that seemed to be the only way to get the roof to go Shed. The front (high) wall of the 2nd floor needs to be about 10 ft tall, and the back wall needs to be 2-3 ft tall. I have the front wall marked as High Shed/Gable Wall, the back as a Knee Wall, and the two side walls as Full Gable. In the video I watched, the side walls automatically adjusted to fill in, and the high shed wall bumped up as well to the height it needed to be for the roof pitch (which I have set as 3" in 12). I just can't seem to figure out where I've gone wrong and would very much appreciate some advice!
    • By jheath21
      I'm working on this project for a summer class.. I'm finished and was taking perspectives and a couple ray trace. I changed some of the settings in the ray chase for lights and such, and then I move to another part of the building and the ceiling is gone!! What did I do wrong? And how do I fix it?! Please help!!
      I attached a snap of the outside of the building...no ceiling in the center (also I know my glass panels extend above the ceiling don't judge me)
    • By Flach2
      I Just wanted to introduce myself. I’ve been in the building business for 25 plus years, mainly remodeling, (some new homes). Cabinet maker, finish carpenter, remodeler among other things. (I know how things go together!) Can communicate with Architects, builders & remodelers well. Have been certified in & using Chief since version 6. Have been working remotely all over the country for many years. I work fast & reasonably, usually from a matter of days to 2 weeks turn around time. Please see my work here: www.theprojectdesigners.com Plan examples & references available on request.   Thank You for Considering me, Tom Flachbart from The Project Designers   603 770 6078 tom@theprojectdesigners.com   Example_Plans.pdf
